CodeMaster
Hi guys,
I have one of the big wooden computer desks, where the tower is supposed to sit inside an enclosed area. It is open in the front, but partially closed at the back. At the moment the PC is sitting outside the desk, and my idle temps are ± 48°C.
I have in the mean time ordered a "Zalman CNPS9700 LED CPU Cooler" to help with the cooling, but I am sure if I put the PC back into the enclosure, I will STLL have a temp problem, even with the Zalman.
What I would like to know, would it be possible to cut a hole in the rear of the desk, mount a 120cm fan, and solder a USB cable to the fan. Does USB supply enough voltage to run a 120cm fan?
An alternative I guess, is to use a 220v fan, but where can I get a 120 - 150cm AC fan?
