howardb
Hi all,
I had to re-wire our ornamental garden lamp this weekend - it used to run off 240v and had a day/night CFL globe in it. I decided to go the 12v low voltage route and used an on-hand small 20w 12v G4 halogen fitting that was already pre-wired and had it's own 12v power supply brick that came with it. BTW everything in/on the ornamental lamp is watertight/waterproof.
I also decided to replace the G4 20w 12v halogen globe with a 2w waterproof LED globe instead, but still run it off the same power supply brick. Anyway, switched it all on last night around 7pm and all looked good and working; however after about 30 minutes the power supply was VERY hot, to the point of smelling electrical burning, so I switched it off - below's a photo of the power supply and globe used - wondering what the issue could be that is causing it to "overheat" so quickly. The 2w LED uses 10x less wattage and the current draw certainly cannot be more than a few hundred mA; I'd think its much less than a 20w halogen draws?
Any ideas before I go and buy a different power supply to try?
