2 problems - need help pls
Vember
hi all
the first which i think is not possible -
my dad has a calender on Microsoft outlook which he synchronizes with is Nokia N73 calender , yesterday he deleted a meeting in order to get the update from his laptop next time he synchronizes - but it sync'ed in the wrong direction - the cell phone updated the laptop and now a very important meeting (with all he notes in the details are) is erased
Is there any way of getting it back? or is it lost to the big hole?
secondly -
the same laptop just got really slow , very slow , and after a while of working or fighting with it to work .. it wants to shut down so it "dumps" the memory then restarts,. The thing is it just started one morning.. it did not progressively get slower, and he did not install any new hardware or software.
Is there any solution to this? Should I remove more software , or is the only solution to upgrade the ram?
thanks for any help
RE laptop - backup data, format and install Windows from scratch, and install a good antivirus program first before restoring the data.
As for the calendar, don't think it's possible to recover the meeting details. Maybe your dad can phone somebody for the details?
How old is the laptop?
not old hp laptop, reformatted in November
Have avg on it atm
[edit] compaq nx9010
You prob can recover the calender date, did you try nokia suite?
It can be used in conjunction with Microsoft Outlook.
ye thanks that is what we use, can one recover it?
