2 problems
Geriatrix
Right here
Right, 1. Does anyone else in Randburg have a lot of disconnects and slow speeds the last two days?
2.And here's another problem. I unintentionally broke the VMC software by removing the 3G connection from my connections tab in Internet Options(don't ask) and after discovering my unfortunate mistake tried to reinstall it. But alas.
It won't install. It just crashes when I press the accept button on the terms and conditions page. No error message, nothing. It just vanishes. Like magic :) Evil magic...
Also, VMC is listed in Add/remove programs but the option to remove is simply not there.
I tried the old VMC software(v6) and the latest one, nothing works and my OS is XP Home.
Any suggestions?
The slow speeds are pretty much visible all over. Typical symptoms include it slowing down right down to zilch, but normally no disconnects. Fix for this should go in this week.
If you're seeing something else, it might be a local problem, cell-breathing, a new cell that got added, etc.
Log it with CC in anycase, via e-mail.
