Drifter
That is hectic. My Fiesta didnt need a drop of oil between services.
Yea I'm sure there is an allowed usage per spec but damn. That is a lot of oil. I probably need to top up oil on the Figo only around 5k or so and then it's not even a pint. Just sounds very excessive.
Lol. Friend of mine decided to play with methanol on his Stage 1 Golf 7 GTI and blew his engine. VW came back with a quote of R200 000. He took the car to Revo and they're charging him R133 000 to rebuild it. He pretty much destroyed all his internals and he refuses to tell me whether he cracked his block or not.
A single piston is costing him R5 000. Apparently there are no aftermarket forged pistons for the Golf 7 yet.
Take this up with VWSA as it seems like a manufacturing fault on the early models.
http://vwclub.co.za/forum/viewtopic.php?f=94&t=134057&sid=4753486eccc89a5f8f8209c4d33dc572
Met with the dealer principal yesterday.
Without much fuss VWSA have agreed to pay for either the block or pistons or both (basically the cheaper option) should they need replacing.
This is part of their "good will" policy
I will need to pay for labour and consumables (bolts,oil etc...)
They will strip and diagnose and then let me know exactly how much it will cost me and then I can choose to proceed. Should I not want to proceed I will need to pay for the labour to do the diagnostics.
The DP also advised he will add some discount to the final bill at the end.
I need to get this all in writing from him but still feel Im being shafted to some extent.I also find it funny how quickly VWSA came to the party without me so much as sending an email or raising my voice.
What are your thoughts on this?
I got a rough ball park of about 20k for 24hrs of about (this being the worst case scenario of changing the block)
In all honesty Im happy with 6k
24 hours to change a block?
Tell that dealership to get completely fscked if they try that figure....
I have a 2012 Polo GTi, last year June they replaced my engine due to high oil consumption, used around 1L per 500km. It took me about 3 months to actually get VW to admit there was a problem and have them replace the engine. This was around 43000km.
Two weeks ago the car started with the catalytic converter light and EPC light coming. The car would misfire under heavy acceleration at around 4000rpm, it would only misfire there and under light acceleration would not have any issues, the catalytic converter light and EPC light would clear themselves.
The car has been with VW now for the past two weeks with them figuring out whats wrong, they also carried out the compression tests which failed. The latest they busy with now is they going to replace my ECU. Not entirely sure this will solve the problem but it seems to be the steps they following. I am very fortunate that this is all under motor plan. Engine replacement last year turned out to R 86 000.00. Still waiting to see this invoice. They also picked up an shudder with the gearbox (which I've been telling them for the last 2 services) and are attending to that as well.
You can request from the dealer to have VWSA provide you with a courtesy car, they allow it under certain cases.Im pretty sure its a well known issue with VW, especially the oil issue, but getting them to admit it is another issue.
Going to be selling this car as soon as its fixed.
No recent updates from VW? Its quite shocking how they won't admit to any design flaw in these engines, or offer any recall.
