20Mb ADSL2+ Sync Speed
Soulcode
Welkom
Judging by these line stats, shouldn't my line be able to sync higher? Would it improve if I go for VDSL instead of ADSL2+?
Code:
2.1	Type	ADSL2+ Annex A
2.2	Status	Up
2.3	Uptime	0 days 16 hours 56 mins 15 secs
2.4	Line Rate (Down / Up)	15359 kbps / 1261 kbps
2.5	Noise Margin (Down / Up)	15.9 dB / 7.3 dB
2.6	Attenuation (Down / Up)	28 dB / 16.8 dB
2.7	Power (Down / Up)	14.5 dBm / 12 dBm
Code:
2.2	Status	Up
I get about - Line Rate (Down / Up) 19000+- kbps / 1024+- kbps
Electric and nomad1985, how does your attenuation and SNR compare to mine though?
pm telkomZa
he will help you
when i upgraded to 10mb telkom only did 6 and phoned them asked about it said i cant get more exchange limited
but telkom za shorted me out 1st to 8mb on adsl 1
then 2 months ago he boosted me to 10mb on adsl2+
,so ask him,he will fix it :)
pm telkomZa
he will help you
Sorted thanks :)
Code:
2.2	Status	Up
2.3	Uptime	0 days 0 hours 7 mins 23 secs
2.4	Line Rate (Down / Up)	20479 kbps / 1021 kbps
2.5	Noise Margin (Down / Up)	11.4 dB / 14.8 dB
2.7	Power (Down / Up)	18.1 dBm / 10 dBm
Quite impressed. Recently upgraded from 10mb and using Axxess's double your data account...
Recently moved my line to the 20mbit, havent upgraded my uncapped account yet to 20mbit. So far I'm also pretty impressed with the service.
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (dB): 126 116
Attenuation (dB): 160 60
Output Power (dBm): 0 111
Attainable Rate (Kbps): 25712 1196
Rate (Kbps): 20479 1019
D (interleaver depth): 1 1
Delay (msec): 0.9 0.24
2.2 Status Up
2.3 Uptime 0 days 0 hours 3 mins 13 secs
2.4 Line Rate (Down / Up) 20331 kbps / 1019 kbps
2.5 Noise Margin (Down / Up) 6.3 dB / 11.1 dB
2.6 Attenuation (Down / Up) 20.5 dB / 8.3 dB
2.7 Power (Down / Up) 0 dBm / 12.1 dBm
