Got a picture? Male female? If it is like a floppy drive connector you could "trim" a floppy cable, or gently take one off a floppy cable.
No, that’s a 5.25” drive (old Emulator II style) for the really large and literally ‘floppy’ discs...Not the right one
Are yiu looking for an 8" drive?![]()
The normal PC 3.3" stiffy uses a 34 pin connector, so they must have made up their own board to fit on the drive. As a last resort, you could try swapping the board on your drive with that on a stiffy as long as the interface to the hardware is OK. Obviously yhis will only have a chance of working if the board is till OK.
That's just the point I won't know if the boards still working unles I first get the Floppy drive working or at least know that it is working...The chances of the Flash Ram not working could be noted, the whole point is I need to get it to someone who is an expert fixing computers to look at it as the E4K is a computer in it's self
The I guess you've got very little chance of success unless you can find a user group
I suggest, if you haven't already tried, that you try and find contacts at
http://www.keyboardmuseum.org/links/links.html
http://www.emu.com/support/custsup.asp
http://www.emu.com/support/legacy.asp
as a starting point.
Good luck!
You're ten fscking years late to the party!![]()
