How much ram do you have...?![]()
32bit OS only pick up 3.2GB, anything over that need a 64bit OS to fully utilize the additional ramIm running 64bit and Im very happy with it. Other than that though there isn't a giant difference between the two.
which is better? (windows 7)
FarCry 2 64bit is also better over 32bit.Well, for starters you'll need 64-bit drivers for all your hardware. As long as you don't use anything too dated or any specialist hardware, you should be fine, considering Win7 was only released recently. As for gaming, some older games may have a bit of trouble running, but that's a general Win7 problem, not specifically isolated to 64bit Win7. There are reports of some games (Crysis: Warhead 1.1 is the only one that I know of for sure) performing better in 64-bit mode than in 32-bit mode. In terms of viruses, I don't think there's any difference.
But since you've got more than 3GB of RAM, I'd recommend 64-bit Win7 to make full use of your RAM.
64 bit Windows Vista and 7 have a feature called PatchGuard that protects the kernel of the OS from a heck of a lot of attacks from malware. This isn't a magic bullet, as you still need anti-virus, but PatchGuard makes life harder for things trying to get in, and that is a good thing.
Performance wise you aren't going to notice much difference, especially in day to day work. If you running heay rendering or other apps then you will. In some cases there may be a *small* slowdown, as 32 bit code gets run through the WOW emulator.
