3G Antenna
dr0ne
Hi Guys,
I've got a client just outside Middelburg, where there currently is no telkom and adsl coverage.
I've installed a 3g router there, but the signal is very unstable. It is normally on only 2 lines of signal strength.
Its a linksys router with a 3g pcmcia card plugged into it. I'm currently using the little antenna that you get with the card, but its not working that well!
Is there any outdoor directional antenna that I could use to get a better signal?
Thanks!
Yep Poynting are the best by far. Costs +- R800 depending on the adaptor you choose for your card.
Well worth every cent! :)
