4 Meg Line Help
killadoob
South Africa.
ok so finally telkom give it me but my modem keeps loosing sync
so im down to a 1 meg line and its the only way its stable
has this happened to anyone else?
in my experience when u have troubles with 4meg synch profile u can try 2meg...that should work ok.
but if distance is the problem - 1024 at best.
i live 1 km from the exchange
i tried 3 then we down to 2 now we at 1 :(
o well my dreams of 400kbs are dashed
have got access to your router yet to view the SNR margins?
its called DS margin , SNR down , or RX noise
on 10.0.0.2
or 192.168.1.1
or 192.168.10.100
I was having the same problem, but it turned out that it was all caused by the interference on my line (scratchy noises and stuff) so luckily I didn't have to downgrade ;)
