Hi guys
I called Telkom DSL support today, and ask what is my DSL max limit.
I told them I'm currently at 4Mbps and wanted to know if I can be upgrade to 10Mbps?
I use this to check the ADSL speed checker
It shows - "Your current product speed is : 4Mbps
ADSL availability cannot be determined at this stage, for residential please contact the ADSL call centre on 10210, for business please contact 10217."
They said, you are unable to choose what speed you want, because 4Mbps/10Mbps is in the same package and same price, so you are given the speed and can not choose to upgrade it till 10Mbps.
In other words if you request a 10Mbps line upgrade to your ISP and you're only getting 4Mbps, that means your line area only supports up 4Mbps....
What the hell...with my cousin, which lives literally down the street from me, he can get 10Mbps support and my line cannot be determined?
The funny thing is that, my I check my ISP process log, it stats
"speed changed to 10240 Kbs from 2048:Change of speed to 10240 now active"
"speed=10240,status=InUse,"
But then I got an email from them saying
"Thank you for your email.
Please note that your line speed has been upgrade to the maximum speed of 4Mb,
and is now active.
Thank you very much.
Kind regards,"
But because of this, I went ahead and ordered a 10Mbps data package from OpenWeb...now I'm over paying since I can only get 4Mbps...
This is ridiculous
Key
and is now active.
Kind regards,"
This is ridiculous
Key
