In the process of buying a 50 inch but get mix advise regarding Plasma Full HD or LCD. I spent 80% of time on SD PVR sport satellite, but planning on a HD PVR unit. Which is better. Plasma or LCD. Most importantly there is a vast difference between Plasma HD ready and Plasma Full HD cost. Is is penny wise to go for Full HD. Some advise and steer on this much appreciated.
You'll want to get a plasma - no question about it. Handles SD and sport better generally, and especially at the lower end of the market.
Don't buy the HD vs FHD hype, not even experts can discern the difference from 2.5m+/viewing distance. If
all your media is FHD, or you need to connect to a PC where you'd want max resolution, then sure, you would want to get FHD. Even if you were to get HD PVR, its max resolution is 720p/HD. I strongly suggest you do, for sport especially, you should be able to with your saving by going for plasma compared to more expensive and inferior-for-SD-and-sport ±50" entry level LCD.
The 50" models you'll want to look at, which are the most popular purchases and the "tried, tested and trusted" plasmas, are the Samsung PS50C430 and Samsung PS50C450 (anti-reflective coating, better menu system, USB media player, FM radio, extra HDMI port, and some other small features).
