6-8 hours power during power failures!!!!
rpm
Admin
Staff member
Johannesburg
Posted by: Chloe_r1
Description: Supply power during power failures for 6-8 hours!!! Clean Quiet and Reliable Power during Power failures, our backup power Inverters quietly and instantly power computers, TV, VCR, refrigerator, lights and most electronics for as long as you need. As soon as the grid power comes back, the system recharges for the next blackout. All is happening without you even noticing - whether in the office in front of your computer or at home in front of your TV. There is no better, more cost effective solution for all your power problems such as re-current power failures, power fluctuations, etc. Unlike generators they can be installed indoor, they require no fuel, no maintenance and no spare parts with little service cost. The complete automatic operation of such systems allows you to never have to switch anything on and off like you would with a generator. Yet even compared with very expensive auto start generators these power Inverters are cheaper to install with zero running costs. The INVEREX UPS is a perfect cost effective long backup power system for small appliances such as PC's and small telephone systems. It can also be used in the house! The INVEREX range is an advanced line interactive Uninterruptible power system which is designed to prevent any spikes, sags and blackouts from reaching your sensitive equipment, ranging from computers and telecommunication systems to computerized instruments. Under normal power conditions the UPS filters out all small fluctuations. During electrical power failure the unit employs its internal maintenance free batteries to supply back up power without any interruption. • User selectable for accepting a wider input voltage. • Full automatic silent operation. • Rack and Tower Design. • High Frequency. • Off mode charging. • Compact size for easy storage. • Built-in super charger. • Small scale and cost effective inverter for home appliances and office equipment Power Inverters INVEREX1000 - 1000VA/600W - 6 to 8 Hours Power for 2 x PC, 15" Monitor & Printer (Batteries - 2 x 12V 102ah) R6, 437.00 INVEREX2000 - 2000VA/1200W - 6 to 8 Hours Power for 4 x PC, 15" Monitor & Printer (Batteries - 4 x 12V 102ah) R10, 156.00 These systems supply power for 6-8 hours unlike the normal UPS which only gives you 15-20 min! So if the power goes of you won’t even notice it! Everything gets plugged directly into the inverter and stays there. When the power goes of the Inverter takes over automatically, you don’t have to do a thing! Just forget about it and carry on with your work! We carry a wide range of different kinds of inverters and long backup systems we can supply systems from 500 VA to 85 KVA!!
Price: R6437.00
