70mm Fan
ODTech
Western Cape
Hi all.
I'm looking for a 70x70x25mm "quiet" fan to replace on a Shuttle XPS cpu heat sink but believe it or not i can only find 1 fan but it's a cheapie so i don't want to risk putting it on a CPU heat sink.
I can order them in from America but their quite expensive and the shipping is equaly expensive so i'd rather buy it in SA even if it cost a little more. I'm not eager to pay R500 - R600 for a fan plus shipping.
Does anybody know where i can buy a good quality 70x25mm localy?
Hi all.
Have you tried ebay? I normally save around 80%
Actualy i did see this fan on za.rsonline and i'm aware of the zalman quiet connector. The reason i'm looking for a 25mm fan is because i want to slow it down with the zalman connector and doing that with a 15mm fan will reduce the cfm by too much in my opinion.
I'll go check out ebay, hopefully their shipping cost isn't as high as frozencpu.com
