8800GT Water Cooled
rpm
Admin
Staff member
Johannesburg
8800GT Water Cooled
by: SYNERGY
Description: Gigabyte 8800GT 512MB 256Bit With Aqua Viva Duo Liquid Cooling Solution. The Aqua Viva Duo comes with 2 Water Blocks, 1 is in use by the 8800GT, the other unused. Can be used to cool your Intel/Amd CPU, for a dual cooling solution! Or it can cool 2 Graphics cards in SLi. Brackets to mount the CPU included. Boxes for both products. The Cooling Solution is by Cooler Master, and actually does a very decent job in cooling the graphics card. Got a *20 degrees drop in Temperature, and is silent. Excellent for Performance PC's and Overclockers. SMS: 083 786 7819 Preference to Durban Buyers
