Hi Where can I get firmware to flash/reload this device please?
http://www.telkommobile.co.za/devices/detail/huawei-e367
Thanks Stokstert however i do not se the E367 8ta firmware there, or is it included in the connect software which I just need to reinstal?
What happened is I have cellC and 8ta sticks, and while fiddling and installing software the other evening through beer goggles, I had the 8ta stick plugged in but did a cellC instal and now by default when I plug the 8ta stick in it boots cellc connect software, (2 different machines same behaviour)
It still works and I can connect, but i figure the cellc software mighta overwritten what was on the stick, if that makes sense, so want to flash the stick.
Just to update. I unistalled all the dashboard software, reinstalled 8ta's and plugged the stick in.
It works but it prompts you with a pop up to install CellC software, the only place it can get that from is the stick itself.
So, I really would like to flash this stick and reinstal the default 8ta firmware if anyone can help with where to get the firmware from, its not on their site.
