According to the coverage map on the 8ta website, I should be getting 3G access in the Southern Subs of Cape Town, but can only get Edge (Roaming on MTN) with very poor data throughput of 30kbps or so. The signal strength is also 0-1 bar, up to 3 bars if I put the modem up on a USB extension and hold it up in the air.
Has anyone else experienced this? Are there some modem settings to force a 3G connection on the 8ta modem? Is an upgrade...imminent?
