acronis trueimage help
killadoob
South Africa.
ok i want to resotre my system every month so i bought this program
could some plz go through the steps i need to take to do this?
start to finish if possible :)
do i need to have windows loaded to do the backup once i've formatted, those kinda noobish question
Thanks alot in advance :)
No you don't need windows loaded however you do need to create an Acronis boot CD. Preferably test the CD BEFORE you format to ensure you can access the backup image from where you saved it.
Just make sure you do not have problems on your OS before backup, or else with every restore backup problems will be back.
The restore is a bit difficult if you have multiple partitions on the same HDD. You do not want to restore the MBR, just the partition when asked.
