Adding 2 more speakers to a stock car system?
Gtx Gaming
Gtx Gaming
cape town
ok so atm i have the stock hyundia cd/mp player that came with atos prime.
Currently there is 2 speakers connected to it which is in the front of the car.
At the back where the boot is there is 2 more spots for speakers .
Was wondering can i add 2 more speakers without blowing the internal amp of the cd player?
and which size speakers does the car take?
was thinking to pick these up for R199
https://www.soundmatch.co.za/Products/Product/909/jvc-cs-v527-200w-2way-5-25-speaker
Problem is, that it's an Atos - an extra 2 speakers and you will lose 50% of your power!! ;)
I know you mean the engine but he'll notice a dip in volume as well most likely due to an underpowered head unit.
fyi the weight will also play a factor in the Atos's performance, 2 speakers could slow it down by 20km/h.
That can be counteracted by adding "Go fast" stripes - you get an extra 5 km/h in each gear (including reverse) per stripe! 2 stripes will do it!! :D
Dropping the suspension also helps, so does getting a different car ;)
At least it's better than the Spark........ Lite.
pfft dissing my car , did not have enough cash for i10 with low km's :p
I use the radio very little but when there is nice song on i like to put up the volume :p
Because you spend too much money on your pc hobbies :P
Although my car isn't much better. Have you figured out how to remove the speaker panel? Because it looks like in my Hyundai you can remove the speaker panel without removing the whole door panel.
speakers are not on door , so yes its not needed :p
unless you speaking about another panel i should know of.
Will be taking the car to soundmatch soon , to get some quotes etc
