impracticaldogg
- Oct 18, 2015
I have some pretty beefy lithium batteries and a basic (Mecer 2400) inverter that works well. Now that loadshedding has gone up so much I'm looking at integrating some solar panels to top up the batteries. As I don't trust the grid to be able to do that before the power goes down again.
What are the basic principles here? I need a more sophisticated inverter (estimate 10k) to handle input from the panels. The panels need to generate enough power to make up for the battery drain. From what I've seen at a friend's place you use batteries to store energy from the panels so the main batteries can also be topped up at night. So they balance out the supply when the panels can't generate energy.
The existing inverter has been connected into the DB board already - so the bulk of the cost should be the purchase and installation of the panels, the new inverter and balancing batteries.
Are there some rules of thumb to calculate the capacity of panels and balancing batteries needed to top up an existing battery installation?
This is why I'm not an electrician..
