TheChamp
Will 75V and 15A be adequate for your application?Just clicked through and this item costs 26k? What about this Victron? There's a factor of ten price difference?
I'm calling a few different people to quote on full hybrid solar vs this kind of supplementary solution. So I'll ask them. I thought installing an MPPT and solar panels with the battery backup would be a much cheaper route than going full hybrid.Will 75V and 15A be adequate for your application?
See i missed somethingHi All,
Long time lurker in the inverter forums. Thanks to everyone and the hundreds of pages in threads, learnt alot, and eventually did my own setup. And in turn have educated others on buying building (sizing, requirements, runtime etc).
Very light setup, but as many have mentioned, some future proofing is always a good idea.
Question, this is the inverter (12v) I have with a lithium battery (Revov 200ah 2nd Life), works like a charm, sees to my needs and capacity is more than sufficient. Now I've always been considering adding a solar panel to the mix, as the inverter is capable (MPPT). But I have no clue how to match an appropriate size to it... or if I'm understanding the data correctly.
Do I just make sure that the solar panel Open circuit voltage )eg, 37V, is within the Operating Voltage of the inverter (15v - 80v)? So what happens if the panel voltage is less than the Inverter requirement like, 10v?
Make sure the Max power of the solar panel eg) 250w, is less than the Max Pv Array input power of the inverter (825w)?
Max power current of solar panel eg) 8A, is within the range given by the inverter Max Solar Charging current (55A total = 25A Utility max +30A solar max)
Now these other bit of data, what are they for:
What is the Max PV array Power to support on the inverter spec (660w), any relevance to matching a solar panel?
Solar Panel Maximum Power voltage is 18v, what is this value for?
Short-circuit current on the solar panel spec 10A? How I understand it is, if the panel goes above the 8A (max power current output) up to 10A, then it shorts? So a fuse on the panel wires rated for 10A would mitigate this?
Lastly, as we know wind and temperature affect solar, how do you size or rule of thumb to select the correct panel to prevent heavy fluctuations in Voltage and Current?
Thanks in advance, on the quest for knowledge.
Inverter Specs:
Solar panel example:
Thanks for BOTH repiles!See i missed something
The max charge amps from solar is 30A
So although the 660w solar will be able to supply is 55A @ 12v
The max that can get into the battery 30A (420w @ 14v ) the rest can flow to load
If no load you lose that extra production
this will just be at noon with perfect sun angle
just sharing what i have read so naturally if you find something i am wrong on do correct meThanks for BOTH repiles!
Now this makes sense. Thank you for illuminating me.
Hope this helps other out there in deciphering these specs.
