My sister got a Telkom 386 ADSL service installed at her home in Primrose about 2 weeks ago. There start the problems. She's got exactly the same hardware setup I have and I know both setups work perfectly because I've swapped components. (shiro modem in bridge mode --> WRT54GL w dd-wrt v24 pre-sp2 ---> PC).
Please help us troubleshoot so we can help Telkom fix the problem.
The symptoms...
- The modem takes ages to syncs, but always does
- After sync (but before connecting to ISP), the modem shows a down speed that varies dramatically from less than 50 to 378 (never 384). If I unplug the modem and force a resync, the new speed is vastly different to the previous speed.
- When I can connect to an ISP, (sometimes I can't and it's not the ISP cause I've tried several), we can sometimes surf (slow download speeds of 2 - 6 kpbs), but after 15 - 20 minutes all traffic ceases completely. Nada. Every ping loses 3+ packets, even to telkomsa. Disconnecting/reconnecting doesn't help - we can't even reach any ISP anymore.
- If we disconnect the modem for 30+ minutes, then reconnect, we can sometimes connect and surf for a few minutes - pathetically slowly, then no traffic and dropped packets again.
What we've done so far:
- reported the problem to telkom on 3 separate occasions.
i) The first time they renewed the port and we were able to connect and surf - slowly - for 15 minutes then nada. They marked the problem as resolved and closed it.
ii) The second time they said they'd move her to another port, and a telkom techy came out to their house, connected his laptop, showed my mother a web page loaded and then left. They marked as resolved and closed. When my sister got home from work exactly the same problem existed.
iii) Third time the techy and I spent 30 minutes troubleshooting over the phone until he was convinced it wasn't a modem/router/setup problem. We even tried connecting to their guest logon account, but nada. Problem reopened
iv) Yesterday their CT support contacted me and said their was line noise and they would investigate from the exchange to my sisters house. If required a techy will meet me at her house sometime during the next few days.
Of course my sister is incredibly pissed at the whole state of affairs and we want to make sure they get it right this time, so....
Advise/Help questions.
- Is line noise likely to be the problem? The telephone works OK and I can't say I hear any noise on the line.
- Could it still be a port problem? Why does a port renew work for a few minutes?
- Why does the line noise go from bad to deafening? ie. why can we surf for a few minutes and then nada... all packets are dropped? Is that consistent with a line noise problem?
Any/all assistance appreciated...
Oh yes, just to remove a software variable, she has ubuntu and windows installed in sparate paritions - theproblems are consistent accross both, so it's not spyware/viruses/OS setup etc.
The symptoms...
