Leakysandwich
Hi all
I have a problem which i'm struggling to identify on my ADSL line and i'm hoping some people may be able to guide me.
(I know some ppl dont like wall of text explanations, but I want to be thorough, so I have included a cryptic version of the problem below)
First, the details:
I have a 4Mbps line from Telkom (was activated 1 March)
I am currently using Afrihost as my ISP
I am the only user on the network
I am using a Netgear router
Cryptic version:
4Mbps internet line VERY (VERY!) slow until I reset my router every evening. Sometimes I need to do this 2-3 times an evening. Telkom doesn't see anything wrong on my line...
Expanded version:
The problem I have is every evening my internet is VERY slow. As in 384kbps or less slow. Sometimes it gets so slow that sites wont even open and speedtests just hangs.
My LOCAL latencies also sometimes goes up to 200-300ms...
Using speedtest.net or other speedtest sites confirms this slow speed and latencies.
I have checked for malware/virusses and there is nothing on my PC that could be responsible for the slowdowns.
What i've found though is that after I reset my router, the speed goes up to between 2.5 and 3.6Mbps again, which is normal for a 4Mbps line. (What is weird is that when the line is 'fast' any type of video streaming constantly pauses to buffer yet torrents runs full speed).
This only lasts for a few minutes or maybe an hour before the speed again gradually drops and another reset is required.
Now I know there are peak times when latency and speed will drop, but this is ridiculous AND my line is unshaped via Afrihost aswell...
I have called both Telkom and Afrihost with regards to this.
Afrihost tech told me that they detect port errors on my line and I should ask Telkom to re-port and reset the line and maybe drop it to 3Mbps.
Called Telkom on numerous occasions but they cannot see any problems on my line, even when it is so slow
. Asked them various times to reset/re-port my line but even after they do it, the speed still drops shortly afterwards.
Also had the line dropped to 3Mbps and it's still happening...
I have also tested the line with an old router that I have and get the same results, so its not my hardware.
No one else I know with a 4Mbps line has this problem and they are getting constant high speeds whether it is downloading/streaming/browsing etc.
So basically I'm sitting with definite line problem, but Telkom doesn't see anything wrong on my line.
What am I supposed to do...?
First, the details:
Cryptic version:
Expanded version:
