Hi, apologies for this long post, but I'm looking for some information and advice on how to proceed with my DSL subscription.
I've got a 4Mb DSL line, which was upgraded from a 2Mb line about 2-3 months ago. The speeds I've been getting are somewhere between 0.3Mb and 1.3Mb. I can't even you-tube on the low res videos - also, it's actually too slow to maintain a connection to the minecraft server I play on.
I've been doing some research, here's the broadband stats on my exchange: http://www.broadbandstats.co.za/exchange/RKVN
But, according to Telkom's ADSL Checker, it says my max speed is 1Mb
My SNR margins are good (well over 10).
So first question is: What does 1Mb actually mean (i.e why), and why does the line sync at 4Mb, and why they then sell me 4Mb DSL when that is the case?
Also - after consulting with my ISP, we ran some test accounts which seemed to indicate that the speed problem is on the telkom side (I guess as above). But as per recommendation, I also logged a fault with Telkom and asked them to please check why my speed isn't great.
The technician came and had a look and said everything on the line is fine, so naturally I asked him why it's slow then, and what I can do about it. He said something about they're upgrading the boxes to fibre in the next month or so and that maybe it would help.
So second question is: Does anyone know what "upgrading to fibre in the next month" actually means? Will upgrading the boxes to be fibre linked give me a faster connection?
Many thanks for any advice or info. Moving forward I'm hoping to work out whether I should just downgrade and wait, or look for other options.
