Hi,
I recently gave up my Telkom landline when my FTTH line was installed. I opted for a Switchtel VoIP line and softphone option (Zoiper) running on my cellphone. Unfortunately my experience with this solution has been quite disappointing. The audio on my side is quite muted an hollow even at top volume. The people I call complain of the same as well as breaks in the audio.
I have in the meantime tested another VoIP service (Freshphone) as well as other softphone options (i.e. MicroSIP on my PC and multiple Android options on my cellphone). Switching my data connection between my FTTH, 3G and LTE resulted in pretty much the same outcome. With Switchtel you can also change your codecs between medium and high bandwidth quality - this made almost no difference except for a slight increase in the volume on the higher option.
My next step would be to invest in a physical VoIP handset for my home office, but I am worried the bad call quality will persist.
Any advice from other VoIP users? What is your experience with these single line VoIP services?
Thanks.
Thanks.
