leon.davibe
- Feb 3, 2009
To be honest , i would always recommend going to 48v systems that can take solar for later
1 the charge rate is much better ie you will always be able to get the battery full , especially if you expand the battery capacity later
2 more solar capacity, and you can run most of the house with some scheduling during load shedding if you have enough battery/panels
Many start with a small inverter/battery and then feel they should have gone bigger
Then buy bigger device down the line , or do the whole stepping stones to eventually end on 5kw/8kw system
The money is better spent just getting a 5kw from the get go imo
