Android automation
TheHough
If you looking to automate functions/routines on your Android phone/tablet go and download Tasker from the Play Store.
https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm
I use it to do the following
1. Auto Tether my tablet when I'm not at home or work. Tasker can record what cell towers you use at home or work and when you are not close to them, then it enables my tethering. This allows my phone to automatically connect to my tab and use its data bundle while out on the road.
2. When my phone pairs with my car hands free, I use Tasker to connect to my A2DP Belkin bluetooth device in my car and load TuneIn to start streaming the best radio station in the world.... www.ballz.co.za
3. If my phone is plugged in to charge after 8pm, Tasker is set to silence the phone, hide the led notifications and re enable everything when unplugged or after 6am in the morning.
If anyone else has cool Tasker profiles, please share them here.
Set all volumes to max when connected to car bluetooth. This serves two purposes: max volume for A2DP audio, but also sometimes I mute my phone during meetings but forget to unmute thereafter. Now tasker fixes that when I drive away from the meeting.
A certain phrase in an SMS triggers a loud noise and causes my phone to return an SMS with its whereabouts included.
I did not realise you can disable LED's. Is that done through TeslaLED?
