wigsel
- Nov 25, 2016
I fitted an Android unit into my Amarok and it works well.
The problem I am experiencing is this.
When I start the vehicle the Android unit reboots because the supply voltage drops to around 9 volts. I have checked the battery voltage during start and it also drops at the battery. I have had the battery load tested and was told that it is good. It is also charging correctly and is less than 6 months old. Also the engine does not battle to start so all seems good that side.
What can I do to ensure the supply to the Android unit stays at 12 volts during the engine start?
Has anyone experienced this?
