ABDurbs
I am having countless issues with my inverter which does not have solar panels connected, just mains power.
Since installing it, the unit is using battery power for something, but not trickle charging the batteries. Battery voltage went from 13.3v down to 12.2v overnight whilst plugged into the mains.
I was initially told to change setting 02 to AGM because my Hubble S 100’s do not communicate with the inverter.
I also changed setting 13 to UPS. I have made no other changes to settings so I suspect that is where the problem lies
When I tested the inverter by switching off the mains, it did not switch over to the inverter.
If somebody knows this inverter, please advise what the correct settings to change are.
GETA-LB-EU 1.5K/12V
2 X HUBBLE S-100A CONNECTED IN PARRALEL
LOAD OUTPUT TO A PLUGBOX
GETA-LB-EU 1.5K/12V
