Another SGS user MMS problem
corp
Sandton
There seems to always be problems with MMS on these splendid phones. I am running Darky's ROM v9.5 and before had no problems with MMS. I have deleted old MMS settings and done the device setup via the *111# service but still not luck.
Error message: The application Messaging (process com.android.mms) has stopped unexpectedly. Please try again
I have reinstalled Darky's (no wipe - this shouldn't be necessary IMO but what do I know), restarted numerous times and installed settings from scratch. Any ideas on a solution?
You on vodacom? when mine stopped working i just used the *123# prompt from mtn and it all worked okay afterwards. So I don't know what is causing you to not get the device setup.
I am on vodacom. Will maybe put in a mtn sim and see what happens.
