It does support band 41 if I force it, I get 3 bars and around 40mbps. I'm hoping maybe a better router that supports band 38/41 without forcing it can give me better speeds.So try it and let us no if you got it fixed
If the speeds aren’t good on 38 then it won’t be good even on a other router ... that’s my thinking if anyone no better it’s a friend I no on this MBB ... I’ll see if I can tag cavedogIt does support band 41 if I force it, I get 3 bars and around 40mbps. I'm hoping maybe a better router that supports band 38/41 without forcing it can give me better speeds.
Yes, you will but there are many other factors that determines the speed you get from LTE, like location of the towers, congestion and so on.But you will get different speeds with different networks isn’t it and depending on the router model
Makes sense now ... I’m getting a B525 router that’s why I’m asking ...Yes, you will but there are many other factors that determines the speed you get from LTE, like location of the towers, congestion and so on.
So I am with both Telkom LTE and Afrihost MTN LTE, with Telkom being service I've had for the last 4 years. It was only earlier this year that I started looking into Afrihost MTN. Before I registered with Afrihost, that is when I did the testing with the 2 routers. With Telkom, I was getting speeds anywhere between 5 and 12mb using the B525 and speeds generally doubled when using the B618. Now with Afrihost MTN, I am getting speeds between 37 - 50mb using the B618. I haven't tried the MTN sim in the B525 yet though but I am still using the Telkom sim in the B525. The Telkom contract will be expiring soon so I will probably just upgrade my Afrihost contract when this happens. Unfortunately Telkom speeds have degraded in the last few months.
Are buying or getting for free?Makes sense now ... I’m getting a B525 router that’s why I’m asking ...
Getting one for free ... But everyone is saying it’s not worth it but if I’m getting one I can use it ... I mean it’s better than nothing right ? Or I can sell it and try getting a B618Are buying or getting for free?
Hey, if it's free then go for it. If signal is not good, you can then decide to either install external antenna or get a B618 router.Getting one for free ... But everyone is saying it’s not worth it but if I’m getting one I can use it ... I mean it’s better than nothing right ? Or I can sell it and try getting a B618
Thanks buddy I’ll definitely look into this ...Hey, if it's free then go for it. If signal is not good, you can then decide to either install external antenna or get a B618 router.
