dunkyd
Anyone know where I can buy? Just need a few more metres of coverage after buying wife an A10s which loses signal in the bedroom.
Krugersdorp area ?
Krugersdorp area ?
Wouldn't this work out to your personal advantage? Wink Winkafter buying wife an A10s which loses signal in the bedroom.
Thanks, obviously my age doesn't show up hereWouldn't this work out to your personal advantage? Wink Wink
But, if you're not interested in having her be more dependent on you for entertainment in the most sacred room in any marriage, then order the antennas and their adapters online from distributors like Poynting, Miro, Scoop, DBG, etc.
Also, for additional range, connect her phone to the 2.4 GHz WiFi network of the router instead of its 5 GHz WiFi network. (If her phone is already connected to the latter, click on the phone's network connection settings and select Forget Network.)The WLAN module of the Huawei B612 operates both in the frequency range around 2.4 GHz and 5 GHz and supports the 802.11ac standard.
Extension cord? Cheapest, simplest option.Cannot move the router due to power point positions.
No, no, no, no, no, NO!I'd get something like this, you can get cheaper ones that do the same job. Antennas aren't going to help you improve WiFi signal.View attachment 902968
Well it works for me, literally needed 2m of extra coverage, did the job for like 100 bucks at the time.
Agreed, but not the cheapest ****, which is bound to cause endless hassles and troubles. (Anything with that particular design shape that is certified less than AC1000 should not even be considered, as a rule of thumb.)a cheap repeater is the next best thing
You must ask why Huawei never even suggested that ????I'd get something like this, you can get cheaper ones that do the same job. Antennas aren't going to help you improve WiFi signal.View attachment 902968
Thanks, reminds me of camping in Wilderness in 1983. I covered a braai grid in foil and picked up tv channels unheard of before in the areaI think I did read somewhere that those dipole antennas are supposed to increase the WiFi range but I'm not sure whether this is true or not. Maybe you can report back?
Have you tried to use a pot lid, wok, sieve etc. close to the router to see if you can reflect the WiFi signal back to the router?
If that helps then you could make something more permanent from cardboard with a layer of aluminium foil. There are many designs on the internet such as this one ...
How to build your own Windsurfer Antenna
On this page I will give you detailed instructions on how to build your very own Windsurfer Antenna for very few pennies. The reasons you may need a Windsurfer Antenna may vary but generally the u…rchelimenace.wordpress.com
