anyone can help me setup wvdial
nolo
hi fellow linux
I new to linux <still learning>
I am currently using slackware 13.1 32bit
and i have been all over the forum
looking for solution to how to connect the cellc 3g card
i currently have wvdial as it was the only software
available after searching internet for connection manager
I even installed wine hoping that i could run the windows
network manager to only find out that the is some
DLL netsomthing.dll missing
any help will be welcomed
I on slackware cuz i want to learn how to develop software
First off you need to leave the mxit speak out...
It just makes it a lot more difficult trying to understand where you at and
what exactly you trying to do! :)
Trying to connect using wvdial and a 3g modem on linux will typically involve 2 or 3 files:
1) Script file that powers up/down the modem
2) /etc/network/interfaces where network interfaces are defined
3) /etc/wvdial.conf where you setup dial rules
Here is a snippet of wvdial.conf:
[Dialer 3G]
Modem = /dev/ttyACM1
Init1 = AT+CGDCONT=1,"IP","internet"
Stupid mode = 1
phone = *99#
username =;
password =;
You need to define the device where your modem can be reached in linux
as well as APN settings and user/pass on that apn.
In the /etc/network/interfaces file you may define a 3g interface:
# 3G interface - ppp
iface 3g inet wvdial
pre-up . /usr/local/etc/F3507g; ifup F3507g; python /opt/ServiceAssure/F3507g.py ppp
provider 3G
Note the pre-up script calls to turn on the modem in this case an F3507g ericcson modem.
provider 3g is the dialer config within the wvdial.conf file.
And now you can connect with the command "ifup 3g" and similarly calling "ifdown 3g"
will stop the connection.
@udiS3 thz for the reply
do i need to code 1) or are the scripts on the net i can grab?
2) is this done with through pppd?
3) APN settings and user/pass on that apn? do i need to call cellc to get hold of this settings?
Nolo,
1) Here you want to talk to the modem on it's control channel and power it up and optionally
unlock the sim for use. This is done by using commands from the modem's AT command set.
Most commands will work with most modems! But there are variations between modems so it
would be wise to find the AT command set for the modem you are using.
Try to find a script that someone has written already for your modem would make life much easier
for you!
However you could just as well modify an existing script to make it compatible with your modem. An
easy way to check commands is to run them using the linux chat command...
As an example here is a snippet of my script file (F3507g):
CONTROL_DEVICE="/dev/ttyACM1"
PIN="0000"
APN="internet"
bringupsim() {
if [ -c "/dev/sim" ]
then
echo "sim device exists"
else
echo "creating sim"
mknod /dev/sim c 251 1
echo O > /dev/sim
fi
powerup_F3507g () {
echo -n "Powering up F3507g card.."
while [ ! -c $CONTROL_DEVICE ]; do sleep 0.5; echo -n "."; done
echo "done"
echo -n "Turning on F3507g card..."
sleep 3
echo "bringing up sim"
bringupsim
sleep 3
echo "bringing up modem with SIM active"
/usr/sbin/chat -v "" "AT+CFUN=1,1" "+PACSP1" > $CONTROL_DEVICE < $CONTROL_DEVICE
sleep 12
/usr/sbin/chat -v "" "AT+CPIN?" "SIM PIN" "AT" "OK" "AT+CPIN=\"$PIN\"" "OK" > $CONTROL_DEVICE < $CONTROL_DEVICE
sleep 6
/usr/sbin/chat -v "+PACSP1" > $CONTROL_DEVICE < $CONTROL_DEVICE
echo "done"
powerdown_F3507g () {
echo -n "Turning off F3507g card..."
/usr/sbin/chat -v "" "AT+CFUN=4" "OK" > $CONTROL_DEVICE < $CONTROL_DEVICE
echo "done"
You can test the chat commands to see if they work individually!
2) This is a text file on your machine that defines the system network interfaces.
3) For Vodacom/mtn the settings are:
apn: internet
username and password blank or guest.
I assume Cell C would be the same?
http://www.flexispy.com/Mobile APN Setting to use GPRS.htm
@udiS3
usb_switch works and the settings for wvdial work what i need now is to setup network interface
@udiS3
Awesome! Go ahead and edit the /etc/network/interfaces file with any text editor...
As an example:
provider 3G
The first line states that the interface is managed by wvdial and the last line specifies that
the 3G dialer from wvdial.conf should be used.
/etc/network/ does not exist in my slackware 13.1
/etc/rc.d/ seems to be the file that exist when i google the internet
for /etc/network
This is what happens when i run wvdial
since i did not do step 2
root@darkstar:~# wvdial option 3g
--> WvDial: Internet dialer version 1.61
--> Cannot get information for serial port.
--> Initializing modem.
--> Sending: ATZ ATZ OK
--> Sending: ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0 OK
--> Modem initialized.
--> Idle Seconds = 300, disabling automatic reconnect.
--> Sending: ATDT*99#
--> Waiting for carrier. ATDT*99# CONNECT 7200000
--> Carrier detected. Starting PPP immediately.
--> Starting pppd at Thu Aug 11 14:38:57 2011
--> Pid of pppd: 2208
--> Using interface ppp0
--> pppd: PPw· [06][08]*[06][08]
--> Disconnecting at Thu Aug 11 14:39:28 2011
--> The PPP daemon has died: A modem hung up the phone (exit code = 16)
--> man pppd explains pppd error codes in more detail.
--> Try again and look into /var/log/messages and the wvdial and pppd man pages for more information.
root@darkstar:~# tail /var/log/messages
Aug 11 14:38:03 darkstar kernel: scsi 5:0:0:0: Direct-Access ZTE MMC Storage 2.31 PQ: 0 ANSI: 2
Aug 11 14:38:03 darkstar kernel: sd 5:0:0:0: Attached scsi generic sg2 type 0
Aug 11 14:38:03 darkstar kernel: sd 5:0:0:0: [sdb] Attached SCSI removable disk
Aug 11 14:38:57 darkstar kernel: PPP generic driver version 2.4.2
Aug 11 14:38:57 darkstar pppd[2208]: pppd 2.4.5 started by root, uid 0
Aug 11 14:38:57 darkstar pppd[2208]: Using interface ppp0
Aug 11 14:38:57 darkstar pppd[2208]: Connect: ppp0 <--> /dev/ttyUSB1
Aug 11 14:39:27 darkstar pppd[2208]: Connection terminated.
Aug 11 14:39:28 darkstar pppd[2208]: Modem hangup
Aug 11 14:39:28 darkstar pppd[2208]: Exit.
Sure its easy. Load Ubuntu or even better...Linux Mint :-)
Seriously though...cant help you with that wvdialer thing. I have never understood that thing. Read up on it a bit but after thirst few lines I got a headache and left it. :-)
slack is my first linux i know that ubuntu is easy, but would not be happy
after getting so close to make something work. To only give up on it, then what was
the point of trying...
besides i don't think linux is difficult if it was well documented ... with easy step by step
most people would be able to setup 3g modems on their linux distro
latest result when i use wvdial i forgot to change the usb port from my first result
when i dial
--> Sending: AT+CGDCONT=1,"IP","internet"
OK
OK
ATDT*99#
ERROR
--> Invalid dial command.
--> Disconnecting at Thu Aug 11 17:37:29 2011
my wvdial settings
[Dialer option]
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
ISDN = 0
Modem = /dev/ttyUSB2
Modem Type = Analog Modem
Baud = 9600
Init1 = ATZ
[Dialer Defaults]
Init1 = ATZ
Stupid Mode = 1
Phone = *99#
Idle Seconds = 300
Dial Command = ATDT
[Dialer 3G]
Stupid mode = 1
password = guest;
username = guest;
phone = *99#
thanks for all your help my linux finally has internet
