Arctic Cooling Freezer Pro 7 CPU Cooler
by: Kuga
Description: Awarding- Winning High Performance CPU Cooler Extremely Quiet The low speed 92 mm fan reduces the noise level to a minimum. The patented fan holder is able to practically eliminate the typical buzzing sound of 92 mm fans. Patent No 203 07 981 U1 (Germany) Patent No 10/834 232 (USA) The PWM chip in the motor allows an exact fan speed control via BIOS. (4 wire) Powerful cooling 6 Heat Pipes (three used double sided) are able to transfer heat up to 200 Watt. The heat exchanger is built of 42 fins and consists of a surface area of over 4700 cm2 and allows for resistance free energy transfer to air. Integrated Cooling of Voltage Converters Air is drawn in from the side of the fan to cool the components around the CPU. Some air is blown out towards the voltage converters o*n the mainboard with the bent fins at the bottom. Patented Vibration Absorption The four rubber connectors o*n the fan case act as a vibration damper to absorb the vibration of the running fan and prevent vibration transfer to the heatsink and the case. Easy Installation The cooler is to install without any tools within seconds. http://www.arctic-cooling.com/catalog/product_info.php?cPath=1_42&mID=72&language=en Bought this and decided not to use it. Buyer is responsible for shipping costs. Brand new in the box. Can contact me on 083 433 5656 or PM me here
by: Kuga
