Article: Rhino poaching calls for drastic measures
The rhino poaching situation calls for drastic measures to be applied, Water and Environmental Affairs Minister, Edna Molewa said on Sunday.
genetically modify the offspring to have no horn. well... it would be nice if we could.
Give me permission to hunt the poachers, I will resolve it no questions asked :D
This is the only solution. Asking nice and putting laws in place wont work. When the choice is a rhino or ones own life, then I believe the latter will be chosen.
Privatize the rhino. We have private cows and private chickens and private pigs and no shortage of them.
The only way to stop the poaching is to remove the demand, and I have already stated the only way this can be done. Nothing else will work. If they're squeamish about a few Chinese keeling over then perhaps they could at least add some sort of industrial-strength skin-irritant to the horn. That should have a similar effect, thought probably not as effective as poison.
Otherwise we're simply have to make peace with the fact that eventually rhinos will only exist in zoos.
It is so so sad :( It's heartbreaking to see pictures and read about this!! It seems that these people will stop at nothing to make money. Not sure what can be done to save them. Maybe built very high electric fences and try keep them safe in the enclosures.
poachers who are caught in the parks with evidence of their poaching, should be shot right there and left for the vultures.
