Article: Warning against illegal water connections
Johannesburg Water has warned that repeated illegal water connections will result in the prosecution of the offender. Johannesburg Water spokesperson, Baldwin Matsimela, said that the department was currently implementing the infrastructure upgrade programme in various areas across the city with the Greater Soweto area being part of the beneficiaries of the programme.
lol... are they going to go after this like they go after the illegal electricity connections? :D
If so, then these people have nothing to fear :D
(except maybe catching some weird disease from a poorly connected supply)
repeated illegal connections?
so you get the first few on the house then?
those customers that have by-passed meters and/or vandalized meters or illegally connected their homes to the system, home owners will first be given amnesty and Johannesburg Water will fix the leaks and replace all the vandalized meters at no cost to customers.
Wow, that's gonna be as effective a deterrant against stealing water as leave with full pay is for corrupt officials. If I had an illegal connection I'd be trembling in my boots at the overwhelming weight and fury of this warning.
Teh DA is trying to DROWN PEOPLE BY LEAVING THE WATER IN THE PIPEZ!!!!11
it izz beta to steel da wata bquaz the lektriciti she shok yoo!! But izz stiil da problim bquaz eye kant swem....................
We believe you! yes we do!!! We believe you cause you can!
What ever.
Effective governing since 1994.
