Hi... Is there any way to apply a MD5 input in ASP...? BUT a very simple way...? Below is the code for the site that I want to add MD5, but note, that this page's password field, must take a normal string and make it MD5 in the DB...
Code:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
<!--#include file="../../Connections/connection1.asp" -->
Dim MM_editAction
MM_editAction = CStr(Request.ServerVariables("SCRIPT_NAME"))
If (Request.QueryString <> "") Then
MM_editAction = MM_editAction & "?" & Server.HTMLEncode(Request.QueryString)
End If
' boolean to abort record edit
Dim MM_abortEdit
MM_abortEdit = false
' IIf implementation
Function MM_IIf(condition, ifTrue, ifFalse)
If condition = "" Then
MM_IIf = ifFalse
Else
MM_IIf = ifTrue
End If
End Function
If (CStr(Request("MM_insert")) = "form1") Then
If (Not MM_abortEdit) Then
' execute the insert
Dim MM_editCmd
Set MM_editCmd = Server.CreateObject ("ADODB.Command")
MM_editCmd.ActiveConnection = MM_connection1_STRING
MM_editCmd.CommandText = "INSERT INTO users (ID, FirstName, Surname, TelNo, CellNo, EMailXCSA, DBAccess, Username, Password) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?)"
MM_editCmd.Prepared = true
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param1", 5, 1, -1, MM_IIF(Request.Form("ID"), Request.Form("ID"), null)) ' adDouble
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param2", 202, 1, 50, Request.Form("FirstName")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param3", 202, 1, 50, Request.Form("Surname")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param4", 202, 1, 20, Request.Form("TelNo")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param5", 202, 1, 50, Request.Form("CellNo")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param6", 202, 1, 100, Request.Form("EMailXCSA")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param7", 5, 1, -1, MM_IIF(Request.Form("DBAccess"), Request.Form("DBAccess"), null)) ' adDouble
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param8", 202, 1, 50, Request.Form("Username")) ' adVarWChar
MM_editCmd.Parameters.Append MM_editCmd.CreateParameter("param9", 202, 1, 50, Request.Form("Password")) ' adVarWChar
MM_editCmd.Execute
MM_editCmd.ActiveConnection.Close
End If
End If
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>IT Admin | Add Admins</title>
<link href="../../assets/css/SiteGlobal.css" rel="stylesheet" type="text/css" />
<style type="text/css">
body,td,th {
font-family: Tahoma, Geneva, sans-serif;
</style></head>
<body leftmargin="0" topmargin="0">
<div class="HomeHeader"></div>
<div class="DivWrapper">
<div class="ITHeader">Add Administrators / Webmasters</div>
<div>Content for New Div Tag Goes Here</div>
<div>
<form action="<%=MM_editAction%>" method="post" name="form1" id="form1">
<table align="center">
<tr valign="baseline">
<td nowrap="nowrap" align="right">FirstName:</td>
<td><input type="text" name="FirstName" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">Surname:</td>
<td><input type="text" name="Surname" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">TelNo:</td>
<td><input type="text" name="TelNo" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">CellNo:</td>
<td><input type="text" name="CellNo" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">EMailXCSA:</td>
<td><input type="text" name="EMailXCSA" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">DBAccess:</td>
<td><select name="DBAccess">
<option value="" selected="selected">..select</option>
<option value="1" >1</option>
<option value="2" >2</option>
<option value="3" >3</option>
<option value="4" >4</option>
<option value="5" >5</option>
</select></td>
</tr>
<td nowrap="nowrap" align="right">Username:</td>
<td><input type="text" name="Username" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right">Password:</td>
<td><input type="password" name="Password" value="" size="32" /></td>
</tr>
<td nowrap="nowrap" align="right"> </td>
<td><input type="submit" value="Insert record" /></td>
</tr>
</table>
<input type="hidden" name="ID" value="" />
<input type="hidden" name="MM_insert" value="form1" />
</form>
<p> </p>
</div>
<p class="Footer">Copyright © 2009 Xstrata Coal South Africa. All rights reserved | <a href="#" class="FooterLinks">Internet Usage Policy</a> | <a href="#" class="FooterLinks">IT Department</a> | <a href="#" class="FooterLinks">Credits</a></p>
</div>
</body>
</html>
