Sinbad
- Jun 5, 2006
It's a lot of fun actually, on my other car I enjoy it when you floor it and the instant fuel consumption goes to the max of 38.4 l/100km![]()
This one will go way past 100
^very good summary
The reason why a car needs to run with the water at a certain temperature is also to help with atomisation of the fuel. If the cylinder head temp is too cold, the chance of unatomised fuel running down the cylinder walls and causing oil dilution and eventually premature wear to the rings and the cylinder bore increases.
Engineering is fun![]()
Mine did that a few weeks ago on long road going away for the weekend. Went down a long down hill, had the car in 5th and by the of the downhill it went from 3 bars down to one bar, then after a few minutes of driving and giving petrol it went back up again. What does that mean? Problem????
which often kept the fan running for a few minutes, to cool the radiator down when you switched off the ignition and the temp gauge needle was hovering in the middle position
Talk of this issue makes me miss my old air cooled XT550 with kickstart![]()
