Jonny Two Shoes
Hi there,
Who is any good with audio cables? I would have flunked sound engineering class lol
Anyway I have a cable which fits into a speaker from a PC. On one side the jack is small enough to fit into a standard audio port on a PC. On the other side is a really large jack which fits into the speaker.
I have noticed that the smaller side fits perfectly into most PC's. However with some of the latest Dell laptops this is not the case. The smaller side no longer fits flush into these. It makes a very poor connection and is almost useless to use at presentations and what not.
Does anyone know if Dell have changed the spec somewhat? If there is a way I can tell what I need to get it to fit properly? Is it just me?
