Hi guys,
I need some major upgrade advice because there are a plethora of choices out there and I am so confused about what to get.
I currently have a Sony Wega 74cm that i have been using as a main TV for the last 7 years but am now in a position where i can upgrade to something substantial in the form of a LCD/Plasma. There is a second room in the house and about 18 months ago i bought a 32" HD Ready Samsung LCD for that room - have been quite happy with it.
I also have a PS3 which i use to play some games from time to time but it's primary use has been as a media player (video music and photos). I love my PS3 but i think it sucks at media playback due to its inability to play some of the formats out there. I usually end up loading the media on a stick and watching it on the Samsung (which seems to play everything so far) but i would like to be able to watch media on my main TV if I want.
I also have a fairly good PC which I use to keep the bulk of my media, browse with on the internet and some occasional strategy gaming (also watch a bit of anime)
The audio has been derived from the TV and it has been adequate for now but I also wouldn't mind upgrading this area either
I want to have an environment where all my devices are interconnected so that i can stream my media easily.
This is what I think I need together with some of the choices I have in mind. Have also attached budgets next to each.
40" LCD TV (R7K)
I am not bothered with 3d and 40" is the size that I want. I really like the UA40D5500 as it's a great looking set and fits well within my budget. Was tempted with the 5003 that went on special at Game recently but was very alarmed at the lack of inputs and felt that this could limit the use of the TV. Have also considered plasma but the TV will be used quite a bit in the day and the impression I get is that plasma won't work very well in these circumstances. The other concern is that i have heard that channel logos can get burnt into Plasmas but these may very well be areas that have been addressed with newer models. My only gripe with this TV is that I don't know if I will really use the Smart functionality seeing that I have a PC and a PS3 at home and can use this for my apps, internet use, etc. If SMART TV is not all that it is cracked up to be then the LA40D550 may very well suffice but it may not be as good looking as the UA40D5500
Wifi Router (R1,5K)
Will plug this into my PC so that my media can be streamed wirelessly to PS3 and possibly the TV. I am using a 3g internet connection so a router with 3G may be preferable but I can always leave the PC switched on if I need to.
I have also looked at the powerline networking options (Billion range) but have not seen enough written up about this locally to determine if it's a decent solution. I also would like to integrate my second TV into the system and the powerline option may work quite well in this regard.
Amp with a 2.1 setup for now (R5K)
Would like to invest in a full blown amp and get a 2.1 speaker set up although this may be overkill at this stage. Am also open to looking at the all in one kits for now as i can always move this into a second room at a later stage.
So that's my situation - would appreciate any help/advice/suggestions
40" LCD TV (R7K)
Wifi Router (R1,5K)
