Iamn0tageek
- Jun 15, 2021
Hi guys,
I need some good solid advice please. I'm sure there have been so many questions regarding what to get in here.
I want to run the following for 4 hours non stop:
1x PC
1x ONT
1x Fibre Router
PC Specs:
1x 550W ATOM PSU
1x MSI A520-Pro or whatever motherboard
1x Ryzen 5 5600G CPU with AMD Wraith Stock Air Cooler
16GB DDR 2666 ( 2x 8GB sticks )
1x MSI GTX 1070 ( Non overclocked )
500GB NVME Drive
6x 80mm fans inside case
1x 120mm Fan
1x RGB USB Keyboard
1x USB Mouse ( Entry level basic mouse )
1x 24" 75Hz Samsung Monitor 1080p
Normal plug in jack headphones
ONT is the basic one from RSA Web ( White box mounted against wall )
Fibre Router is TP-Link Archer C20
What will I be doing in those 4 hours:
Playing games like: ( I like my old games )
DOTA 2
Lord of the rings online
Oblivion
Surfing the web
Watching YouTube in 1080p
Streaming movies in 480p
What I want:
A inverter or whatever that when load shedding hits I can just carry on gaming or whatever without even feeling a dip in the power or whatever.
I want quality regarding batteries. That gel stuff or whatever.
NOTES:
I also want to be able to use my XBox Series S with my 24" Samsung Screen APART from the above setup of PC.
So basically in instance B I want to use XBox Series S, Samsung screen, ONT and TP-Link Router
With all this mentioned, what should I buy?
Obviously I cannot afford like a R50k solution, but I'll budget for the best solution.
Any advice gentlemen?
P.S. XBox and PC will NOT be used together at the same time. Either PC or XBox separately.
I am based in Cape Town - Northern Suburbs
Purchase will be cash.
If you need any more info please let me know.
Thank you
1x PC
1x ONT
1x Fibre Router
PC Specs:
1x 550W ATOM PSU
500GB NVME Drive
1x 120mm Fan
1x RGB USB Keyboard
DOTA 2
Oblivion
Surfing the web
What I want:
NOTES:
Thank you
