Hey guys, so I am in the process of looking at putting a PC together from scratch (first time, only ever disassembled and reassembled old PCs before) and was hoping I could get a few pointers about the parts I have so far put together. Looking at building a rig at no more than R5500 (max budget)
Basically what I use the PC for:
-Gaming, very light gaming: NFS World, Rift, TF2, and the likes. Not really looking for 60FPS but would like to maintain 30FPS throughout gameplay (also Graphics card is not a necessity atm)
-University Work, the odd assignment and research.
-Streaming from PC to Xbox (Videos and Music)
So this is what I've come up with so far, looking at Intel because I've only ever used it, but I am open to using AMD.
CPU: Intel i3 4160 3,6GHz R1482
MB: Asus H81M-K R700
RAM: Corsair ValueSelect 4GB DDR3 1600MHz R510
HDD: Western Digital Caviar Blue 1TB R780
PSU: Corsair VS 450W R500 . Is this PSU too powerful? I have seen a Thermaltake Lite Power 450w PSU for about R300
Case: CoolerMaster Elite 344 Mini Tower Micro-ATX R450
Optional: LG DVD Drive R180
MS Windows 8.1 64 bit R1130
Only items being carried over are: mouse, keyboard and LCD Screen
Currently this build sits at R5700-ish but with that Thermaltake PSU it will come down by about R150, so closer to R5500 budget.
Also just a few Qs:
-Is the motherboard/PSU too advanced for this build and would it be better to go for a lower spec one?
-Will the PSU fit in the case? (how would you know if it does? or does not?)
Hope you guys can help, Thanks for all your help in advance
Also just a few Qs:
