marco79
Which batteries should I use to replace the ones in my Xbox 360 controllers? Are rechargeable ones fine? Is 2100mAh ok? Or should i just replace them with the normal alkaline ones the controllers came with?
Consider get a Play and Charge Kit. I have used rechargeable batteries before and it fails when compared to the Kit.
