Battery connection
Anton654
Hi, how would I go about connecting 6 100ah 12v batterys to a 3kva 24v inverter, is it possible? Current I have 2 12v so thats easy lol. I'm guessing it would be a series/parallel connection but I'm not sure how to connect 6 batterys. Thanks!
Can you connect 2 in series for one bank of 24V?
You are going to have 3 banks of 24 volt batteries going to inverter
Please for the love of God ensure that the cable lengths going to inverter are exactly to the cm the exact same length
I am not going to preach again how important this is when you have miltiple banks
I learnt my lesson the hard way years ago
Look here at this link
I went with option 3 and have never looked back
Im using 10 batteries in parallel
Theyre all 100% healthy today
Yes Method 3
Method 4 just looks too complicated for me with 10 batteries
LOL You beat me to it
Thank You
And can everyone on this planet please bookmark that page? You will not regret it
You are using a bolt to join the wires. Do you have a nut in between the lugs (lug/nut/lug/nut) or are all the lugs together?
I just wanted everything to come to a spot where they're all as close to each other as possible
I hope that is Lead acid and not LiFePO4's?
Cause 99% of the 100 AH LiFePO4 BMS cant do 2 x 3/Serial x Parallel
