The S-100 is a 1C 100Ah lithium battery designed to be a drop in replacement for existing Lead Acid or Gel batteries.
The S-100 has a integrated BMS inside the battery container, which also contain the prismatic lithium cells.
The S-100 can be connected up to 4 times in series maximum. You can configure the batteries in 12V, 24V, 36V or 48V in series.
It is important to note that there are two versions of this battery:
• The older Hubble S-100 (with serial # prefixes starting with DS) can be configured in series or parallel, but not both simultaneously. This means that one or more older Hubble S100s can be configured:
o Series: 1, 2, 3 or 4 batteries; OR
o Parallel: Up to 15 batteries only in 12V configuration.
• The newer Hubble S-100 batteries (with serial # prefixes starting with HL) can be configured up to 4 batteries in series with 4 batteries in parallel.
o This means that a bank of 16 batteries can be configured at 48V, with a maximum discharge and charge rate of 400A and 200A respectively
