battery for generator
jphegers
Centurion, gauteng.S.A.
I have a Power Master 7.5 Va power generator, i have probably emailed and phone over thirty places trying to find a replacement battery to no avail.
Is there anyone who can give me info as to where i could find a 12 V 14 AH battery or a similar lithium ion battery , i tried a 12 V 18 ah battery but it is too big to fit into the generator.
Batteries Unlimited, Marconi Beam Industrial, Western Cape.
Give them a call, they do even the most obscure lead-acid batteries you'll ever see
Try regal security
  • 12V 17 Amp hours sealed lead acid battery
  • Dimensions: 180mm (L) 76mm (W) 167mm (H)
Get a smaller one then. The capacity is less important than the cold cranking amps rating.
I need to find a new one of these - I've been using one of those portable battery boosters to start the generator (mostly because I'm too lazy to pull start it)
What is the lifespan of a power booster jump starter because they are Virtually the same as a what a litium ion battery for my generator will cost?
Hi jphegers. Did you manage to find a battery? I've been all over Pretoria today to find one.
I hope that it's a 7.5kVa generator :)
I suspect that it's a whitelabelled Chinese GenTech Industries genny?
Many were sold by Builders' under the "GRIP" label.
Tada
sys-master%2Froot%2Fh86%2Fh23%2F9814367272990%2F99-7802767-Angle+A_large
