Battery + inverter advice required
DaveO
East Rand
I hope that one of the other esteemed gurus on the forum can give me some advice here. I seem to get conflicting advice from salesmen, depending on what they are trying to sell / have stock of.
Having just received our newly revised load shedding time-tables, I have decided that some backup power is going to be a must to ensure continual productivity as we are now due to be 'hit' at least 4 times a week during working hours.
As I can't use a gennie ( townhouse complex ) I have decided that the best solution would be a charger / battery / inverter option.
I'm looking at using 2 deep cycle batteries ( 94 Ah or 105 Ah, depending on supplier ) connected to a 20A charger and 1000W inverter, with household power required for essential items at a max of about 550 W. This should give me about 4 hours backup time.
My question relates to the necessity of having a UPS for my PC equipment. My understanding after initial research, is that I could have a UPS so that the UPS supplies uninterrupted power to the PCs while I go flick the manual change-over switch. I assume that the inverter is always in the 'ON' state, but does nothing until the change-over
switch is used and power starts to flow from the inverter to my equipment (?).
However, do I need the UPS if I do the following :
connect the charger to the battery to the inverter ( therefore continual top-up / maintenance charging of the battery ).
then connect the inverter to the change-over switch, to my power board ( for supplying battery power for lights, TV, etc when required )
but connect the seperate circuit that my PC equipment is on ( PCs only using about 300W - no printers ) directly to the inverter so that the PCs are always using the inverter power, thereby using the inverter instead of a UPS, and the batteries are always charged fully, and the inverter would therefore, in reality, be using the power supplied by the battery charger, and would also be isolated from fluctuations in the municipal power supply.
When the power cuts, the PCs continue using the inverter's power ( uninterrupted ) while I go flich the switch to route the inverters power to the rest of the essential appliances in the house.
Also :
1. would you recommend an automatic change over switch ? if so, can anyone tell me a make / cost / source ?
2. any recommendations ( make / cost / source ) for the best deep cycle batteries to use for this system.
YES, you should definately tell me. Thanks. I really would like to believe that this is the case and that I never have to worry again. But then this is the real world and the chances of the utopian situation are extremely slim.
Due to the nature and time sensitivity of the work that I do, spending 10 or 15K on a 'just in case' solution is small change, compared to my inconvenience and problems if the power dies at the wrong time of the day for me.
So if anyone does have some info relating to my original post, it would be greatly appreciated.
Not to sure how to answer your question but in my case i use ups's on all my machines which hold us over until the genny starts. Point being always use a ups between mains or the inverter-battery scenario. Shal have to research the inverter choice some more as i am also looking into it for my persoanl machine which i do not connect to the genny
If I had R15k to spend I'd buy a APC Double Conversion Online UPS + 100Ah 12v batteries, but if you don't want to have to do modifications your best bet is to get a Inverter solution that already incorporates the battery charger. A 20 amp battery charger won't be able to sustain a 1kW inverter (unless it's supposed to be 20 amps @ 220V, doubtful thought).
Remember if the Inverter is 90% efficient (example), it uses 1100kW of power, that is about 92amps @ 12volt. The charger wouldn't be sufficient, not even close.
