nickv
hi.
can anybody help please.
my phone: Hisense HS-U909
op sys: android 4.04
problem:
up until 3 days ago i had BBM for android installed & working correctly no problem. out the blue , my messages stopped going through & my contacts could not send me messages. the app still worked & showed its status as "connected" . at this point i had changed nothing on my phone, no new apps installed or uninstalled. I then decided to unstall the BBM app and reinstall it. now when i try open the app it constantly gives me message saying " no connection found. your connection to the wireless network is turned off.restore your connection and try again"
what i've tried so far:
1. uninstall & reinstall the app. same result
2. tried accesing through Wi-fi connection. same result
3. swopped sim cards (i have a 2nd vodacom sim) . same result.
4. through *111# tried to reset the OTA internet settings. same result
5. through the my vodacom web portal tried to rest the OTA settings. same result.
only other IM app installed being WhatsApp works normally.
help please???
problem:
help please???
