jphegers
What are the top makes, and most reliable car batteries to buy.
Apparently, they are all very much the same - if it swings, you're ok. Batteries like Bosch and Middas are just rebrands of the same thing.
I do, however, believe that Willard is a little better than the rest.
SABAT for me.
I got to fancy batteries in the past, and it got swapped, once during a service and the other at the panel beater. So look for a good price at a good dealer.
a friend wanted to save and got another cheap battery which did not fit well and it crack and the acid damage was over R10 000.
