hj2k_x
Howdi.
So my quest to get my machine cool and quiet on a tight budget is nearing completion.
I have turned the 20cm propellor on the side of my Aerocool case off, and added a 12cm, silent exhaust fan at the rear to expell the hot air pushed out by the 12cm fan at the front.
The heatsink and fan on the AMD X2 5200+ is still stock. I might look into getting some kind of cooling for this. It is not too loud but it is quite warm...I have seen a few options for around the R200 mark.
Now, the 8500GT is another story. I managed to get the one with the fan on the GPU and not the heatsink so it is not only LOUD but also warm.
I want to remove the stock fan and put something quiet and cool on there. (and cheap) Any ideas?
Bear in mind that this is not for overclocking purposes. I just need the machine to run quiet and cool when idling. Which it is not doing right now...
All comments appreciated
